Click icon to watch this demo on YouTube (Internet Connection Required) |
Enable Channels
Click
on the Enable button in the Toolbox.
the Edit menu click on Channels...
or double-click on the Channels:
field
in the status bar. This displays the Channel Selection grid.
The current enabled status of all connected device channels is displayed in this grid. The Channel Selection grid allows the user to enable and disable all input channels. All channels are enabled/disabled with a left-click on the channel box. Analog Input channels show a checkmark when enabled. The general-purpose digital channel (channel 9) displays an "I" when enabled. The Rate channel (channel 10) displays an "R" when enabled. The Count channel (channel 11) displays a "C" when enabled.
View Channels
the View menu click on Format
Screen. In the Format Screen box, click on the desired display
format.
View Format Screen (ALT, V, F). In the Format Screen box, select the desired
display format using ↑ or ↓ keystrokes. Press ENTER.
Screen. In the Format Screen box, click on User-specified
format….
View Format Screen (ALT, V, F). In the Format Screen box, select User-specified
format… using ↑ or ↓ keystrokes. Press ENTER.
Enter
the desired number of channels to be displayed (up to 16 overlapped),
and click OK. You also have the option of overlapping
the specified number of waveforms. To overlap the waveforms, click the
Overlapped check box. An X appears in the box indicating an overlapped
format. A subsequent click removes the X, indicating a non-overlapped
format.
Enter
and press ENTER. You also have the option of overlapping the specified
number of waveforms. To overlap the waveforms, press the TAB key until
a dotted box appears around Overlapped, then press the space bar. An X
appears in the Overlapped check box indicating an overlapped format. A
second press of the space bar removes the X, indicating a non-overlapped
format.
